went to track with trick flow kit!!!!
RE: went to track with trick flow kit!!!!
Thats good mph for the time. Last time I was at the track, I ran 13.12 at 107mph with 2.14 60'. I think you would really benifit with some stickys. You had a not so good 60' get some tires and 12s is very possible.
why are u racing a car with no tune? that would have sucked if it went lean up top.
also you can get the et streets in a 255/50 R16
i would start looking into some upper and lowers. i had a lakewood traction action lift bars and bbk uppers. i would suggest getting some steeda adjustable uppers so u can adjust the pinion angle. just trying to help u learn from my mistakes.
i doubt he'll go lean with a "mild" set-up and 30's...i was cutting 12.5-12.8's with 107mph...
suspension...good springs/upper/lowers/struts/shocks,and a decent sticky tire will net every bit of a 12 sec pass
I have the 30's because i got a great deal on them and the mass air meter. Im not really sure where to sset the fuel pressure with them. I know i would be better with 24's. What fuel pressure and timing you recommend?
no chip yet..with your set-up...16* timing and 36-38 psi for the 30's....i'm running 43 psi on my 24's and go waaay lean when i hit 6500.
that is why i bought a pms...although someone will surely chime in megasquirt is cheaper than a mail order chip
ORIGINAL: Jasperstang308
i didn't see the 30's. why do u have 30's and then on top of that ur fuel pressure was set at 40. i bet that car is running rich as hell.
Nice trap regardless, what elevation are you at?
