went to track with trick flow kit!!!!
#24
RE: went to track with trick flow kit!!!!
Im not sure of the elevation. I was racing at indianapolis raceway park. Where the big boys run. With my vacuum hooked up it pulls fp down to about 35psi. I have never heard of unhooking it. You think that would really help out?
#25
Mine is 38psi with vac. line connected. Unhook the vac. line and plug it, and set the pressure to ~43 at idle. You'll be set. That setup tends to peak around 5800, so that would be a good point to shift. Don't waste money on a chip though, get a dyno tune. You'll get faster, be sure you're not going to blow up, and also find out the best shift points for your specific car (and get some numbers!).
#26
a dyno would help ya on shift points...i always go 300 rpm over my peak...this will also tell ya how lean/rich you are.
you can manipulate alot with timing and fuel..
every engine is different...you might be ok with 30's at 40 psi and you might not...ever see puffs of black smoke? eyes burn when you walk behind car when running...it might be ol'school,but it works...i have been through 4 different cams and two different set-ups,and let me tell ya they are night and day..
#27
ORIGINAL: stangman5892
#28
Ya i will be there at wfc 10!!!!!! Im just tryn to get the car in the 12's. It looks like elevation is 700 ft but that doesnt sound right. Im just not sure where to set everything. im kinda new at all this. If you couldnt tell. lol Does your mph get better with a better 60'?
