351W Piston Questions
Old 04-03-2007, 07:54 PM
Hurricanedt77
Hurricanedt77's Avatar
Default 351W Piston Questions
Should I reuse my stock pistons in my 351W. I'll be spraying a 100 shot w/ a set of Trick Flow TW Heads anda .520 Lift Flat Tappet cam. Although I'm not going to bringing the motor upwards of 5,500 Rpms. So in short, would it be safe to reuse the stock pistons here, or get a set of aftermarket Pistons. BTW, I'm not going to Bore it, just a hone. Thanks for the help
Hurricanedt77 is offline
Old 04-03-2007, 07:59 PM
408guy
408guy's Avatar
Default RE: 351W Piston Questions
well whats piston to cylinder wall clearance now?
408guy is offline
Old 04-03-2007, 08:18 PM
my77stang
my77stang's Avatar
backyard redneck rule of thumb # 101: if you can catch your fingernail on the ridge at the top, it needs to be bored. very vague but its somewhere for the adverage guy to start. if you dont bore, please - for the love of god BE CAREFULL with the ridge reamer. you can destroy a block really easy with these stupid tools if you dont know what your doing - and you dont wanna have to sleeve 8 holes cause you fugged up
my77stang is offline
Old 04-03-2007, 08:21 PM
Hurricanedt77
I'll remember that, thanks lol
Piston to wall clearence, I dont know. How do I measure, feeler gauge between the Piston and the wall?
Old 04-03-2007, 11:13 PM
my77stang
my77stang's Avatar
no, you mic the piston and then use a bore gauge to check the cylinders at the top and bottom. best bet is to bring it to the local machine shop and ask them to check it real quick, they should just bring the gauge outside and check it while the thing is sitting in your trunk/truck bed/whatever and they shouldnt charge you. if they do, take your business elsewhere
Old 04-04-2007, 01:36 AM
Hurricanedt77
Thanks, what do you think its going to run me per hole to get it bored .030
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
guitarman376
09-30-2015 05:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 351W Piston Questions
