C02
C02
would hooking a line to spray C02 ONTO my intake manifold work to make the air going in a little cooler? i heard that it is possible to suck some of it in the intake and cause hp loss...mines in the fenderwell.
just a thought. im kinda scared of nitrous and c02 is cheaper and i can fill it myself.
RE: C02
Doing that is going to be a HUGE waste of money. If you want to cool your intake, spraying stuff on the outside isn't going to make a big enough difference unless you spray a LOT of it constantly to keep it cool. And even then I'm not so sure it would do anything at all.
I understand that nitrous can be scary, but if you are just looking to cool down the air, just run something like a 25 shot. That level is pretty damned safe and you're not going to see any major problems. You can even go a bit smaller if you can find the right jets and tune it.
If you are dead set against nitrous, then you have two other options.
1) Buy a spacer. I use a 1" spacer and it actualyl does a decent job. It keeps the upper intake so cool that I can hold my hand on it after running the engine hard. It also increases TQ.
2) They do sell water / methanol injection kits for N/A engines that will do what you want. And you can just run windshield washer fluid in it. You're not going to get huge gains but it will help.
RE: C02
ORIGINAL: samseed101
RE: C02
yeah i would just use it when i race...it was just an idea i had. im not against nitrous...i just dont know enough about it and havent used it or been around it.
i have the eddy rpm2 manifolds, would the 1" spacer worh with the stock hood, and maby the strut tower brace (i think its called or somethin like that). also does it come with a gasket or do i need to order one and does it require special bolts because it will be 1" higher?
RE: C02
http://store.summitracing.com/partde...p;autoview=sku
the one for my manifold is only 1/2inch...that wouldnt make much difference. esp for $75 + $10 handling fee lol
RE: C02
ORIGINAL: 94StinkinLincoln
