?301, 351W, 357, 306?? wats th
Old 03-18-2003, 10:17 PM
DirtyDee916
DirtyDee916's Avatar
Default ?301, 351W, 357, 306?? wats th
i was just curious about what is measured in an engine that makes it either a 302 or a 351 etc. is the block the same size and the cylinder is bigger?if a new 351 block was purchased then do normal aftermarket heads fit it ?????? please someone help. thanx
DirtyDee916 is offline
Old 03-18-2003, 10:23 PM
lloydchristmas
lloydchristmas's Avatar
If the 351 block is a W then 5liter heads will fit but youll need a 351 intake. I believe its wider than the 5 liter.
lloydchristmas is offline
Old 03-19-2003, 03:08 PM
devins
devins's Avatar
Block displacement is calculated by two things. Cylinder bore diameter and stroke length. 302 and 351 blocks share the same bore diameter what differs is the stroke length. To achieve a longer stroke length in the 351 they raised the deck height(it's taller). Cylinder heads are interchangable but intakes are not. Not to mention anything mounting to the cylinder heads would be raised causing 302 to 351 swap problems. Unless you want 390 cubic inches plus I'd go 347 with a 302 based block. Save yourself the hassle.
devins is offline
Old 03-19-2003, 09:14 PM
lloydchristmas
Him speakum truth
Old 03-20-2003, 10:52 PM
spike306
spike306's Avatar
yes, well put devins!!
spike306 is offline
uedlose
The Racers Bench
10-01-2015 08:31 PM
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
Daddys Girls GTs
09-14-2015 08:46 PM
DirtyDee916
06-04-2003 01:00 AM
Quick Reply: ?301, 351W, 357, 306?? wats th
