Trouble with the stang
Old 06-06-2007, 07:17 PM
95MustangMan
95MustangMan's Avatar
Default RE: Trouble with the stang
hmm, clean the MAF. How do I go about doing that? Just take it out and clean it with a mild detergent or something?
95MustangMan is offline
Old 06-15-2007, 05:48 PM
95MustangMan
Well, an update. We got the car running after replacing the fuel filter, adding some seafoam, and cleaning out the MAF, however it backfires ALOT now (after reving high and letting off the gas, it sounds like a hot rod), idles extremely low (like about 500 rpms (not 500k), and stalls out. It also seems to drive rough. I can't really think of what else it could be. Any ideas?
Old 06-17-2007, 04:03 PM
chath_brick
chath_brick's Avatar
it sounds like its still having trouble getting gas...backfiring means its running lean. hmmm...you might have to pull and clean your fuel injectors. or you could have something clogging a fuel line. you might want to get the advice of somebody who's a better mechanic than me though
chath_brick is offline
Old 06-17-2007, 04:17 PM
Blckstng93
Blckstng93's Avatar
You got a code for the EGR, so unplug the EGR and plug the line and see if it backfires or idels any better.
Blckstng93 is offline
Old 06-17-2007, 04:44 PM
tmajikman
tmajikman's Avatar
The car may need to just run for a while, clean out all the old fuel, computer has to relearn everything also. Let her sit and idle for a good while and see if some of her symptoms clear up.
tmajikman is offline
Old 06-17-2007, 04:47 PM
88sirneedsalot
88sirneedsalot's Avatar
sounds like water in the gas.
88sirneedsalot is offline
Old 06-17-2007, 04:58 PM
tmajikman
tmajikman's Avatar
Did you ever totally drain the tank, if not, I would, then put some fresh gas in it. Also, have you checked to make sure none of your vacuum lines are leaking?
Old 06-17-2007, 05:20 PM
94StinkinLincoln
94StinkinLincoln's Avatar
drain the tank and check for vac lines leaking...can cause idle surges. also the computer will have to relearn everything so just drive it alot to help fix that.
94StinkinLincoln is offline
Old 06-26-2007, 06:23 PM
95MustangMan
Found the problem! Removed the MAF sensor and the car ran perfectly fine. Going to get the MAF replaced this weekend, so I can get my car back on the road, w00)!
Old 06-26-2007, 06:30 PM
Twisted
Twisted's Avatar
Nice job fellas. I was about to go on a tirade about gas turning to varnish, and other such nonsense. Glad you figured out the problem, man. Enjoy that new (to you) Mustang.
Twisted is offline
Quick Reply: Trouble with the stang
