What cubic inch motor should I build?
Old 06-14-2007, 07:04 PM
NYMustang50
NYMustang50's Avatar
Default What cubic inch motor should I build?
I need to figure out what type of motor I'm going to build. It will be a 302 or 306 or a 331. All will be fuel injected and in the end not right away it will be supercharged. So what cubic inch should I build my motor to. What are the dissavantages and avantges to having more cubic inches?
NYMustang50 is offline
Old 06-14-2007, 07:08 PM
turbosha
turbosha's Avatar
Default RE: What cubic inch motor should I build?
bigger the better, im in the process of a 331 twin turbo project. the 331 kit usually dont require and block mods.
turbosha is offline
Old 06-14-2007, 07:09 PM
ih8chevy
ih8chevy's Avatar
no replacement for displacement
ih8chevy is offline
Old 06-14-2007, 07:10 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
more cubes means more power... but stoker engine can rev as high as a 302 could... but unless your running 7k u should have to worry... id say a 331 could handle 6.5k rpms.... if u have the cash a 331 is a nice engine.... 347 is better but that requires some block work.... and they can all take a blower... unless you running rediculous boost... but that wouldnt matter a stock blcok would like 20 lbs of boost with it was stroked or not... they always say they is no replacement for displacement.... if u have the xtra cash do a stroker
CrazyCobraSpeed is offline
NYMustang50
I want to make the car a daily driver so thats why Im not going 347 if anyone asks.
Old 06-14-2007, 07:12 PM
P Zero
P Zero's Avatar
Since its all going to be the same block and wont weigh any more than the other, do a 331.
-P.
P Zero is offline
Old 06-14-2007, 07:13 PM
86 5.0L
86 5.0L's Avatar
Im happy with my 302 and its plans but do what you wanna do, I myself like say 302
86 5.0L is offline
Old 06-14-2007, 07:14 PM
NYMustang50
Will the AOD be able to handle the 331 or will I need to put in a c4 if I keep it automatic.
Old 06-14-2007, 07:15 PM
w8less
w8less's Avatar
331 all the way.
w8less is offline
Old 06-14-2007, 07:19 PM
P Zero
P Zero's Avatar
ORIGINAL: 86 5.0L
Personally, I like the 302 as well, theyll rev faster than the stroker motors. THeyre setup perfectly for revving. I drove 1 stang that spun 10k, craziest sound I ever heard out of a SBF.
-P.
P Zero is offline
Quick Reply: What cubic inch motor should I build?
