do i need caster/camber w/ 4cyl springs???
Old 06-30-2007, 07:59 PM
ford91mustang
ford91mustang's Avatar
Default do i need caster/camber w/ 4cyl springs???
i heard that u need caster cambers when u lower your car and i just bougt 4cyl springs for the front of my car along w/ other suspension mods and wasnt sure if i needed them or not...let me know what i should do
ford91mustang is offline
Old 06-30-2007, 08:48 PM
stang8689
stang8689's Avatar
Default RE: do i need caster/camber w/ 4cyl springs???
it can't hurt but are u using the coil spring isolaters
stang8689 is offline
Old 06-30-2007, 08:49 PM
w8less
w8less's Avatar
u won't need them not a big enough drop
w8less is offline
Old 06-30-2007, 11:57 PM
luckythirteen13
luckythirteen13's Avatar
jasper is right, i run the 4 banger springs on my car with no cc plates
luckythirteen13 is offline
Old 06-30-2007, 11:59 PM
ZachW04Stang
ZachW04Stang's Avatar
I was able to get caster and camber in spec when I had 4 cylinder springs.
ZachW04Stang is offline
Old 07-01-2007, 12:05 AM
luckythirteen13
if you really want them, go for it. but the drop isnt enough to warrent the need for them
Old 07-01-2007, 12:12 AM
ALMOST STOCK
ALMOST STOCK's Avatar
The consensus seems to be if you'velowered your car at least 2" , or if you need more adjustably you'll need them.
ALMOST STOCK is offline
Old 07-01-2007, 01:24 AM
dimebag
dimebag's Avatar
i have 4banger springs and no cc plates.... not needed
dimebag is offline
Old 07-01-2007, 01:40 AM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: ALMOST STOCK
I think to do it right you need CC plates before a 2" drop. I would get CC plates for anything over a 1" drop.
OnyxCobra is offline
Old 07-01-2007, 01:51 AM
stang8689
stang8689's Avatar
depends if he leaves the isolaters on, if you leave them off i would get them , but not a big deal
Quick Reply: do i need caster/camber w/ 4cyl springs???
