Engine mounts
Old 07-10-2007, 11:11 PM
Blckstng93
Blckstng93's Avatar
Default RE: Engine mounts
This is for a 79 correct? In a previous post you werent sure. The first VIN digit will be a 9 if it is a 79. As for the engine in it now did it come with the car? If not what is the 5th digit in the VIN? If its a T (straight 6) that may be the problem. I dont think the K-member for a straight 6 works with a 302, even with 302 motor mounts.
If thats not the problem then something has to be bent, or you got ripped on those mounts.
For a 79-85 youll need a new trans cross member (doublehump) for a true dual exhaust, and a few hangers for the other muffler/tailpipe.
Blckstng93 is offline
Old 07-10-2007, 11:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
If you were close you could borrow a set I have 2 sets sitting around some polyurethane ones and stock rubber ones
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
robjh22
Suspension
09-08-2015 12:47 PM
09-01-2015 08:16 PM
Quick Reply: Engine mounts
