what radiator
Old 07-03-2007, 05:49 PM
scooterstang
scooterstang's Avatar
Default what radiator
i've decided to bite the bullet on my car running hot and just purchase a new radiator. I need to keep the car cool, but i do not need to over do it. its a pretty much stock car, but it is also my daily driver in the arizona, where it's hotter than hell.
what brand of radiator do you suggest?
I was just thinkin a regulat aluminum would work?
scooterstang is offline
Old 07-03-2007, 06:10 PM
ROTTITANK
ROTTITANK's Avatar
Default RE: what radiator
Im running a Visteon. It running much cooler. But it was 400 bucks. Ford racing raditor,thats not going over board and still good.
ROTTITANK is offline
Old 07-03-2007, 06:27 PM
7upedition
7upedition's Avatar
get a 3 core copper/brass replacement with a 180* t stat... a flush your coolant, be sure the system is free of air
7upedition is offline
Old 07-03-2007, 08:15 PM
SoDakStang
SoDakStang's Avatar
ORIGINAL: 7upedition
P.s. Those u/d pulleys aren't helping you cool at all. You're gonna run hotter since your water pump isnt spinning as fast. Something definitely bigger than stock like above. I lived in Tempe and had no problems with stock everything. Throw those pulleys on and **** heats up.
SoDakStang is offline
Old 07-03-2007, 10:07 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
well is your clutch in your fan worth a crap?....I use a flex fan $25.00,3 core brass rad..about $135.00 and a 180 stat..$8.95..stays nice a cool
2 kwik is offline
Old 07-03-2007, 10:14 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 2 kwik
You forgot to mention it's a MR. GASKET t-stat
PRO50SC is offline
Old 07-03-2007, 10:18 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
I gave up
2 kwik is offline
Old 07-03-2007, 10:21 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
I have the Summit-brand Aluminum radiator...with a 180 thermo...and a Ford Racing Water Pump......it runs COOL!!
CantStopTheFox... is offline
Old 07-03-2007, 10:23 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 2 kwik
I gave up
[sm=goodidea.gif][sm=icon_rofl.gif]
PRO50SC is offline
Old 07-03-2007, 11:29 PM
stang8689
stang8689's Avatar
ford racing aluminum is only $245 at c.j pony
stang8689 is offline
Quick Reply: what radiator
