cheap stroker kit with stock bore?
Hey guys is there a stroker kit for the 302 that uses the stock size bore. Im looking for a kit that keeps the stock size bore so i don;t have to get a lot of machine work. By the way im not looking for anything bigger then 331 cubes. Any one know if there is a cheap kit out there?
RE: cheap stroker kit with stock bore?
If it's a used block, you should really consider cleaning up the bore. It's a small price to pay in the grand scheme of things. A stroker is a pretty good investment. I can sell you a .030 over kit and you can bore the motor for the same price as you can spend on just the standard bore kit elsewhere. But if you really want to stay standard bore, I can do that too. I can get you whatever you want.
its a brand new 302 sportsman block so thats why i want to stay standard bore, what kind of cubic inchs can you do now that i think of it i can go bigger then a 331 if its possible
A few people (very few) have to clearance the block for a 3.25" stroke. With a 3.4" stroke, you will have to clearance the block. Using a standard bore, the 3.25" stroke (331) kit will make a 327" motor. The 3.4" stroke (347) kit makesa 342" motor.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
