wont start.. ugh
Old 07-10-2007, 02:44 PM
nacanitihs
nacanitihs's Avatar
Default wont start.. ugh
ok so this morning i went to go start my car to drive to work 645am and it just was turning over but wouldnt fire up.. i tried it a few times w/ no luck.. so i had to ride my motorcycle.. when i got home just now i tried it again and got the same thing... i can hear the fuel pump prime. what should i do?
nacanitihs is offline
Old 07-10-2007, 02:54 PM
red9535
red9535's Avatar
Default RE: wont start.. ugh
Your car needs air fuel and spark to fire. If the fuel pump is priming, that's not the problem. Check your ignition fuse.. it might be blown. Did you try giving it a little throttle while it was turning over? Then check spark plugs.. no spark = no run. Worn out plugs = barely starts, runs like ****.
red9535 is offline
dimebag
dimebag's Avatar
check spark
dimebag is offline
Old 07-10-2007, 02:57 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: red9535
Not necessarily true. Bad regulator (or broken vacuum line to the regulator) would allow the pump to prime but not let the fuel past the regulator.
Derf00 is offline
Old 07-10-2007, 03:01 PM
nacanitihs
nacanitihs's Avatar
hmmm yes i did try pressing the gas but that didnt work.. ill go check the spark now.. it has a newish msd blaster coil that is about a year old, and the plugs are only a couple months old... oh and ill check the fuses
Old 07-10-2007, 03:11 PM
nacanitihs
nacanitihs's Avatar
damn i forgot you need 2 people to check the spark.. one to tuirn it over and annother to hold the plug...
fuses are good...
i havent driven it in a couple days if that matters
Old 07-10-2007, 03:12 PM
mattdel
mattdel's Avatar
you dont need two people. get an inline spark tester. it plugs into a wire and plugs onto the plug, or cap. then you just crank, and it lights up if there is spark
mattdel is offline
Old 07-10-2007, 03:48 PM
nacanitihs
nacanitihs's Avatar
ok it has spark... and i checked the inertia switch and thats not it.. any ideas?
Old 07-10-2007, 03:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
If it has spark then put a fuel pressure gauge on the rail and check pressure if there's a blockage somewhere pressure will be slow to build if at all even though you hear the pump run doesn't mean all is well with the fuel system check the regulator... pull the vaccum line make sure no leaks are there and check for injector pulse with a noid light
mjr46 is offline
Old 07-10-2007, 04:09 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: mjr46
i hate it when my stuff gets rephrased and posted as new.... although you did add to it and not just rework it
Derf00 is offline
Quick Reply: wont start.. ugh
