HCI 99% Complete - Help with last line! *NEED HELP!*UPDATED**
Okay... I go to start the car after HCI and it won't start... I try again and the car just made the loudest popping noise pretty much making me go deaph and woke up my neighbors! Could this have been an extremely loud backfire? Also I didn't put oil in the lifter valley (i forgot)... I did put oil in the car and coolant... i've done everything but this last line to hook up...
Anyways I hope I didn't just break the car but I found one line is undone from the upper intake manifold, please tell me where it goes... I can't find it...
Heres the picture, I put a red arrow pointing to the line... i'm ****ing pissed...
RE: HCI 99% Complete - Help with last line! *PLZ HELP!*
It's not related to the line you're pointing to, but are you sure your distributor isn't 180 degrees out? Popping / backfiring is a very common symptom of that.
ORIGINAL: samseed101
also where do you know where that line goes?
I don't... so say i'm on the wrong one now... which I 90% most likely am now that it backfired... I can't get to the crank bolt now with everything back together.... BUT are you saying turn the distributer so that it points 180 degrees the opposite direction?
ORIGINAL: nothsa
i think he means that you set the timing to the intake stroke instead of the power stroke. when you install the dizzy you have to set it to the 1st cyl when the 1st spark plug is supposed to go off, not when the valves are open.
no. you need to manually crank the motor over the #1 cylinder is on compression stroke TDC. then you need to re-stab your dizzy so its in the correct position. if you still have trouble use this as a referance. https://mustangforums.com/m_3264510/tm.htm
ORIGINAL: VigCS
Also, that loose hose is your PCV hose, should have the valve in the end of it. Goes in the back of your lower intake.
Yeah I kept trying to start the car bcz I was like wtf and i've honestly never heard any car backfire as loud as my car did. My neighbors come outside thinking a bomb blew up their house...
So.. NOW... HOW am I going to spin the crank.... VIG what did you do, I don't want to remove the fan/ shroud/radiator...
