thumper e7's
Old 07-11-2007, 01:36 PM
1bad91
1bad91's Avatar
Default thumper e7's
was considering buying the thumper e7 heads. are these any good. if not does anyone know were i can get a decent set of heads for around 700?
thanks
1bad91 is offline
Old 07-11-2007, 01:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: thumper e7's
Why not spend a tad more for a set of aluminum ones??? world products sell some cas t iron headsfor under 1000.00 and I believe RHS has good deals on their website for heads
mjr46 is offline
Old 07-11-2007, 01:45 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
im not even going to respond the E7 comment. i would suggest calling up RHS and getting a quote, those puppies are awesome for the price
FivePointOhh is offline
Old 07-11-2007, 01:46 PM
FivePointOhh
in limbo
ORIGINAL: 1bad91
thanks
__________________________________________________ ____________________________________________
91 Gt
mods:
CHP 331 stroker
bbk ssi intake
bbk equal lenght shorties
off road x-pipe
24lb injectors
1.7 roller rockers
70mm tb
flowmasters
4.10 gears
upper and lower control arms
2500 stall converter
shift kit
and that thing up there....lose it quick
Old 07-11-2007, 02:27 PM
my77stang
my77stang's Avatar
whats that place that sells the GT40 and GT40P heads with big valves and stiff springs for cheap? adder knows what im taking about but i cant remember the name.
that might be an option if your looking to score some good heads for cheap - and yes the thumper ported heads do very well from what everyone says
my77stang is offline
Old 07-11-2007, 03:04 PM
1995mustang818
1995mustang818's Avatar
yup get rid off that bbk ssi and get a holley intake manifold or an eldelbrock rpm 2
1995mustang818 is offline
Old 07-11-2007, 03:56 PM
1bad91
1bad91's Avatar
ya i've had lots of people say get rid of the intake. I havent had any problems with it though. whats so bad about it?
1bad91 is offline
Old 07-11-2007, 05:46 PM
FullAuto
FullAuto's Avatar
I have a set of Thumpers. They perform well, but they are not good bang for the buck.
FullAuto is offline
Old 07-11-2007, 09:24 PM
dillon1340
dillon1340's Avatar
ORIGINAL: FullAuto
did you notice a big difference by using the thumper heads? why do you say it's not a good bang for the buck? they are only like 500 bucks
dillon1340 is offline
Old 07-11-2007, 09:27 PM
blackout
blackout's Avatar
ORIGINAL: dillon1340
ORIGINAL: FullAuto
+1
I just got my ported e7's install from him, i'm about to get the car running from the HCI hopefully tomorrow. Anyways I have the ported e7's, e303 cam, new timing chain, trickflow upper/lower street intake and 24lb injectors. I'm hoping I notice a big difference but i'm going to put some 4.10 gears or possible 4.30's in the rear to help my aod.
Also note... I've only spent $1600 total on my HCI swap... With that I got Trickflow Upper/Lower Street, Ported e7's, timing chain, 24lb injectors, e303 cam, ALL gaskets, and new head bolts and so on. I didn't want to spend $2200 total when the e7's flow just as good as AFR 165's. PLUS i'm not planning to pay a another $300-500 to have the AFR's ported to flow better... Just wasn't in anything I could afford budget wise. I'm just hoping it's worth it!
blackout is offline
Quick Reply: thumper e7's
