Front Struts
Front Struts
Can anyone give me some info on changing them on a 94 gt, was told something about needing special tools for the plates up top. I know i have to get the jack underneath the control arm and unbolt it by the spindle and abs bracket off, just not sure how i take it all out through the top. Thanks
RE: Front Struts
So i just take off all the nuts on the top including the middle one holding the strut and that (sleeve) which looks like a metal plate just slides right off? Do i just attach that sleeve and nut back on the new one? and im done with that or is there alignment issues
RE: Front Struts
You don't even have to unbolt the strut mount at the top, you only have to unbolt the center bolt that holds the strut. The strut bolt is pretty hard to do with hand tools, you will more then likely need an impact gun.
RE: Front Struts
ORIGINAL: Mustangkiler
sweet, will alignment and everything be the same if i just put the new strut in and tighten it up at the top. or at least fairly close?
