VALVE NOISE? OH NO
VALVE NOISE? OH NO
well guys i finished up my motor swap started her up and im getting the dreaded valve noise, its idling fine but making the damn noise.
i let her run for 3 hours same thing, i used 10w30 synthetic blend oil
my valve springs are upgraded hardened springs retainers etc from trick flow, crane roller rockers 1.7 gt40 heads intake steeda #19 cam. Any ideas?
RE: VALVE NOISE? OH NO
http://s172.photobucket.com/albums/w...t=2f3ac990.flv
heres a short vid, sorry for the crappy quality
ORIGINAL: 94 G STANG
the roller rockers do. Readjust them and it should dissapear.
Also look for exhaust leaks indicated by black or white carbon marks
depends on what kinda rocker arm setup you have. are they studs with a locknut on top, or a bolt down style?
you can easily adjust stud style rocker arms, and the pedestal style(bolt down) you will need different length pushrods or shims for the pedestal mount.
ya sorry the rockers are making noise, how do you adjust them?
i thought they cant be adjusted
mine is stock pedesltal mount rockers the same as in the cobra, it has a ford part # and stanger thats great advice
im just sad i have to tear it apart again [&:], i get you until the shim part, you mean add a shim underneath the valve spring? or under the rocker ? Im sorry for the dumb questions but its my first motor build even though im a grease monkey everyday.
