what will a 5.0 do with larger injectors only?
#21
RE: what will a 5.0 do with larger injectors only?
Or he could get a mass air conversion and call it a day... The total cost to do H/C/I isn't all that much if you save it little by little... It's hard, but do a little less driving for a while and that's some extar money right there.
-Jeff
-Jeff
#23
yeah i spend like 10 bucks a day on gas or everyother day
ORIGINAL: nothsa
-Jeff
-Jeff
#24
ORIGINAL: 86GT 93LX
what is the 3bar map sensor? i heard of speed denisty with a 3bar map sensor allowing you to do crazy stuff??
www.google.com
#26
cool, i havent really looked at it yey but its a stand alone ecu right?fully adjustable n stuff? so a 3bar is for turbo
ORIGINAL: 86 5.0L
FYI megasquirt is a Speed Density system
#27
ORIGINAL: 86GT 93LX
if i go to 24lb injectors and change nothing else will i see any differance?
#28
24lb injectors with no other mods will make your car run like doo-doo. A customer had us put in bigger injector into his mustang, with no other mods, and all it proceded to do was load up and foul the plugs. We told him it wasn't going to work, but it was his car and his $$$$.
#29
ORIGINAL: F250sd
Finally the correct answer!!!
#30
because i already have a set i got for free from my friend
ORIGINAL: TAPOUT
Why are you considering injectors by themselves anyways?? You need some other parts to justify the extra fuel. I have a spare set of 88 5.0 heads that have been refreshed for cheap. You should look into a slightly bigger cam, a nice intake and 65mm TB.
ORIGINAL: 86GT 93LX
