Big problems need some serious help brake booster!!!!!
Old 07-16-2007, 11:14 AM
hatchdemon89
hatchdemon89's Avatar
Default Big problems need some serious help brake booster!!!!!
OK so i took my 89 gt out on sunday for a drive anywayz hit the brakes and it isn't stoppin so great i can hear a air noise really loud when u penetrate the brakes lol i mean its loud in the cabin inside the car checked under the engine bay for a vacum leak nothing so i disconnected the bb vacum line an the noise went away what is the problem should i just buy the brake booster eliminated?
hatchdemon89 is offline
Old 07-16-2007, 11:28 AM
hatchdemon89
Default RE: Big problems need some serious help brake booster!!!!!
ok well im goin to work ill check later
Old 07-16-2007, 03:52 PM
hatchdemon89
wow noone can help me?
Old 07-16-2007, 04:07 PM
Twisted
Twisted's Avatar
Doesn't a fat vacuum hose run to a small unit connected to the brake pedal...inside the car? Does it sound like the sound is coming from inside the car or outside?
Twisted is offline
Old 07-16-2007, 04:08 PM
hatchdemon89
inside
Old 07-16-2007, 04:09 PM
hatchdemon89
its wierd idk anything about brakes but the break pedal is heavy an makes a air compressor air noise an doesn't stop great
Old 07-16-2007, 04:15 PM
Twisted
Twisted's Avatar
You may want to stick your head under the dash and have a look. You should be able to see what I'm talking about. I think it's a vacuum bypass unit that the hose goes into--something like that. I can't remember exactly.
Twisted is offline
Old 07-16-2007, 04:29 PM
turbosha
turbosha's Avatar
i think that hose is for the cruise, so when you hit your brakes the cruise kicks off. you probably have a bad booster. disconnect the vac line going to the booster and plug it if you can still here the noise its not the booster.
turbosha is offline
Old 07-16-2007, 05:16 PM
Luckythirteen
Luckythirteen's Avatar
Mine was doing the same thing about a month ago, sounded like an airhose leaking inside the cabin and felt like I was stepping on a brick when I tried to stop.. Turned out the diafram in the brake booster had a hole in it and was toast. Took me about 2 hours to replace it, probably coulda gona faster if I had just removed the master cylinder instead of being subborn and not wanting to bleed my brakes,
Luckythirteen is offline
Old 07-17-2007, 11:21 AM
hatchdemon89
ok guys i know i keep saying something when this thread is old yea when u disconnect the line in the engine bay for the booster the noise goes away i was told to change black valve on the boster ?im not sure
Quick Reply: Big problems need some serious help brake booster!!!!!
