Keeps blowing gauge fuse ><
Hey, I just recently replaced the thermostat and radiator hose, and everything was working fine and dandy and then all a sudden I go to turn it on once it blew the fuse for my gauges, so I replace it, blam, blows again, tried all diff fuses, all blew, I figure theres a short somewhere, any ideas where it might be?
EDIT: 94 Ford Mustang GT Coupe V8 5.0L if that helps any :P
RE: Keeps blowing gauge fuse ><
Quick and easy version: Everything was working great, then it started continuously blowing any fuse I put in for the gauges (speed/tach/temp/etc) and I'm wondering where obvious places might be for a short (Other than "In the dash")
first you need a diagram so you can find out what components are on that circuit meaning all of them not just what the fuse box says!!! cause often times there are things tapped on the circuit not mentioned. but obvious you have a short to ground on the power /B+ side see if you may have pinched a wire while installing the intake??
One: Where to get a diagram? XD
Two: I had someone else do the install of the thermo, so I'm not really sure what you mean "short to ground on the power /B+ side" and where would I be looking anyway?
I don't know much about cars at all but hey I'm learnin ^^;
