Idling problem
Idling problem
Alright, when I fire up the car in the morning in the garage it idles fine, after letting it sit at work outside for 8 hrs ill fire it up and it wants to die, so If I give it gas it'll stay running then after a few minutes it runs fine. Im puzzled[&:]
RE: Idling problem
had the same issue, i changed my IAC & turned my idle up, because when its cold when you crank it up all cars idle higher, but once the motors warm the idler drops more, turn up the idle a bit, and change your IAC, or clean the one on there. mine did that and when i would press my clutch in it would kill only when it was warmed up. that was my issue.
RE: Idling problem
Yea i would def clean, or replacethe IAC.. Cause mine didnt idle too good at first.. Once i cleaned that it was a lot better.. And if it still has that problem, like Ecstasy saidturn up the idle.. Hope it works for ya and good luck..
