Fuel Preasure
Old 07-23-2007, 06:12 PM
LX 90
LX 90's Avatar
Default Fuel Preasure
What is the stock fuel preasure in a 90 5.0, and should it be adjusted at all??
LX 90 is offline
Old 07-23-2007, 06:15 PM
FullAuto
FullAuto's Avatar
Default RE: Fuel Preasure
38.5psi, not unless you mod it to the point you need more fuel.
FullAuto is offline
Old 07-23-2007, 06:20 PM
LX 90
LX 90's Avatar
i have heads cam intake and 24 injectors
LX 90 is offline
Old 07-23-2007, 06:49 PM
LX 90
LX 90's Avatar
LX 90 is offline
Old 07-23-2007, 07:13 PM
LX 90
LX 90's Avatar
bump
LX 90 is offline
Old 07-23-2007, 07:19 PM
5.0stanger
5.0stanger's Avatar
I would just put it at 40-42 and run it. How are those heads working for you....you got the cheaper aluminum ones IIRC right?
5.0stanger is offline
Old 07-23-2007, 07:20 PM
1BIGMOFO
1BIGMOFO's Avatar
From my experience I would get an adjustable fuel pressure regulator and try it out. you deffinitley nbeed one. You can get a schrader valve fpr from summit for like $18.00 and you can get the autometer schrader valve adapter for like $8.00. I would try starting in the 41 range and see. You should know if your car is running rich or lean. try it out for a bit..
1BIGMOFO is offline
Old 07-23-2007, 07:25 PM
LX 90
LX 90's Avatar
The heads are working good. Im getting ready to get a 3000 stall and 4:10s. I just checked my fuel preasure and it stays at 35lbs or 40 with the vacume line off the regulator. When i rev up it goes to 34lbs with the vacume line on the regulator. it never looses preasure all the way to 6500 rpms
LX 90 is offline
Old 07-23-2007, 07:32 PM
5.0stanger
5.0stanger's Avatar
Should be alright, but I would get an adjustable regulator.
Old 07-23-2007, 07:34 PM
LX 90
LX 90's Avatar
yeah i plan to get one along with a fuel preasure gauge
LX 90 is offline
Quick Reply: Fuel Preasure
