chassis braces???
Old 07-24-2007, 04:49 PM
telsonman
telsonman's Avatar
Default chassis braces???
ok, so since i'm about to do an h/c/i swap i'm figuring that i should put in subframe connectors. i've also looked ata strut tower brace and a 4-point lower chassis brace. however i can only really afford 2 of these. i know i need the subframe connectors, but i don't know what i should add on top of that, or if i should even worry about the other 2 yet. what do yall think???
telsonman is offline
Old 07-24-2007, 05:05 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: chassis braces???
i would just buy the subframes. they are worth their weight in gold on a fox because the foxes twist like a pretzel.
if you plan to do a lot of high speed turns then you may want the strut tower brace but if not, dont worry about it.
luckythirteen13 is offline
Old 07-24-2007, 08:12 PM
stang8689
stang8689's Avatar
I have all 3 and they really help around turns. I personally like going faster in turns than a straight line. The lower helps keep a-arms stable and gives better steering geometry. Sub frames help the most, strut tower brace second, lower K-member is only like $55. Get some Eibach sportlines too for handling.
stang8689 is offline
mtgldr
02-03-2024 09:00 PM
guitarman376
10-11-2015 01:47 AM
UrS4
10-03-2015 06:23 AM
09-17-2015 07:57 PM
09-01-2015 08:16 PM
Quick Reply: chassis braces???
