Clutch quadrant, firewall adjuster ?'s
Old 07-25-2007, 07:56 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default Clutch quadrant, firewall adjuster ?'s
Gonna be putting in a new clutch soon. Who has first hand knowledge (not speculation) of what brand quadrant,(singlemount notadjustable)/firewall adjuster that uses the stock cable.
PRO50SC is offline
Old 07-25-2007, 08:01 PM
86 5.0L
86 5.0L's Avatar
Default RE: Clutch quadrant, firewall adjuster ?'s
Search
[8D] The Steeda quadrant and firewall adjuster are good
86 5.0L is offline
Old 07-25-2007, 08:07 PM
WhiteWindsor
WhiteWindsor's Avatar
I have used the steeda. I had the whole set up originally. But my cable broke and i ordered a stock ford cable and used it with the steeda double hook. I had the double hook quadrant and the directions say if you are using stock cable to to use hook closest to firewall. You will have to shave off the 4 ****(or whatever they are called) to use the firewall adj. They have a good write up about it on their web site.
WhiteWindsor is offline
Old 07-25-2007, 08:15 PM
HACKGT350
HACKGT350's Avatar
wow bernie your actually asking a question. i have the steeda double hook quadrant and fire wall adjuster with the stock cable works great but i think i need a new cable soon anyway so i might be getting one of those soon. make sure you take your front seat out to put the quadtrantin or youll have a very very hard time
HACKGT350 is offline
Old 07-25-2007, 08:16 PM
primetime5.0
primetime5.0's Avatar
ORIGINAL: HACKGT350
oh its not that bad... I couldnt ever get a stock cable to work for me
primetime5.0 is offline
Old 07-25-2007, 08:18 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 86 5.0L
Search
You mean like this one? https://mustangforums.com/m_2974495/tm.htm[&:]
PRO50SC is offline
Old 07-25-2007, 08:19 PM
WhiteWindsor
Its not to bad to install. I weigh 250 and did not remove seat. I just layed on my back with feet on the ground, it took me awhile to adjust and get right angle but once i got there it was cake.
Old 07-25-2007, 08:20 PM
mattdel
mattdel's Avatar
damn pro, you keepin tabs on everyone huh...
got your notepad right there with ya and everything dontcha
mattdel is offline
Old 07-25-2007, 08:21 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: HACKGT350
Yeah I know Kyle. I need help sometimes too ya know.
So what's the purpose of the single, double or triple quadrants if there is an adjustable piece at the firewall? I'm not trying to have to go under the dash but one time to install this thing.That's why I'm asking about the single quadrant.
PRO50SC is offline
blkonblk5.0
blkonblk5.0's Avatar
I also have the steeda quadrant, and firewall adjuster..works real good I like it.
blkonblk5.0 is offline
Quick Reply: Clutch quadrant, firewall adjuster ?'s
