The "Fitty" is in recovery!!!
#22
RE: The "Fitty" is having surgury
ORIGINAL: onetrickpony
Did you get new flywheel bolts? If not you really should get some new ones.
#23
ORIGINAL: cleanfitty
Be sure to check this out
http://www.cartechbooks.com/vstore/s...5&CATID=21
ORIGINAL: bighungrymatt
awesome, I am going to change my clutch this weekend, a lot ofthis will be helpful to me as its my first time to change a clutch
awesome man thanks! im sure that will help me a lot
#24
Well, she's all buttoned back up. I buddy of mine had a scissor (sp?) type transmission jack, we got the tranny back in the car very easily. Got everything bolted back up and fired her up..
Everything is doing good, I did aboutthree 5000 rpm clutch drops... just kidding... I took it out for a couple of gentle drives and its doing real good. The pedal adjusted almost by itself, clutch feels pretty good, a bit lighter than the other one.
So...
New King Cobra
New FRPP Flywheel
New FRPP Bolts, dowels, throw out, pilot bearing
New Ford clutch fork
New Ford rear main seal
New 5th gear synchro
Lots of cleaning,even morecussing,
The good thing is that I have put it into fifth gear about half a dozen time and it hasn't grinded yet.. so I'm assuming the trans is going to be fine. I'm going to change the fluid again to get any crap out that may have gotten in there.
No funny noises, no clicking, so I'm happy. I'll take it for a longer drive tommarow...
So...
New King Cobra
New FRPP Flywheel
#28
ORIGINAL: 94 G STANG
you said the pedal was lighter?? my king cobra the pedal was stiff, used my old pressure plate problem fixed.
#30
ahhh re-designed king cobra
By redisigned I meant redesigned as compared to the stock style PP.
Where did your KC from???
Anyway I have put on over 100 miles today in all sorts of driving (mostly freeway) and all is still good. I went into 5th gear over a dozen times and no grinding.
