question for the fella's who use anderson's p.m.s
RE: question for the fella's who use anderson's p.m.s
ok, where can i get to the material, i dont know anyone who has either in person. and i feel like im bugging people on here.
i am building a 408w, and i need to start thinging about the engine management system. witch would you recomend?
there is a website set-up just for p.m.s users all the info you'd need or ever want is there...well it's also for tweecer/fast/diablo ect...just read and you'll find your answer there....bad thing is i forgot the site since someone on my end forgot to write down site when doing a recovery[:@]
you shouldnt need to use the idle control feature. you should be able to set the idle with no problems with it off if you just use the screw on the tb, the tps sensor and add a few degrees of timing at idle in the pms
FWIW Art, there is a new firmware that is in beta testing right now for the MS2. The new firmware will make it compatable with MAF systems. One of the built in settings will be for a typical 88-93 mustang 55mm maf, which we all know.. the 94-95 70mm maf is a direct swap.
So in the not too distant future I plan on offering a direct fit adapter for the MS2 into the stock wire harness, so no cutting or splicing would be needed.
I just need to go gather up a bunch of EEC-IV ECM's
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
