Car Shaking - Shifter Shaker 0 (Very COnfused) NEED HELP!
Ok , My 92 5.0 Is haveing some issue's
My car at WOT lost power?
And is shaking at High Rpm's the shifter shake's real bad to
i know i lost power car doesn't hook up as well something's wrong?
Please help
Please help
RE: Car Shaking - Shifter Shaker 0 (Very COnfused) NEED HELP!
i had a problem with my shifter shaking once and it turned out to be that my driveshaft was loose. i'd check that. don't know about the power loss
sounds like you have a miss if your engine shakes and have a loss of power I'd check ignition components and or compression ====perform a cylinder balance test and narrow down which cylinder has the miss
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
