Motor Mounts
Old 08-04-2007, 02:34 PM
Asylum839
Asylum839's Avatar
Default Motor Mounts
Ok so I need to replace my motor mounts.This doesnt look too hard to do, however does anyone have any diagrams or anything showing the best way to take on this task?
Asylum839 is offline
Old 08-04-2007, 02:42 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default RE: Motor Mounts
Use an air gun...
Cracking those bolts by hand is a B!T*CH!!
CantStopTheFox... is offline
Old 08-04-2007, 03:18 PM
Asylum839
Asylum839's Avatar
yeah I knew i would need a gun in there, But does anyone have any step by step directions, I dont have a manual, I really need to pick one up, But if anyone does have directions over the net that would be great.
Old 08-05-2007, 01:31 AM
CantStopTheFox...
Just get a piece of wood anda Floor Jack...supportthe motor by the oil pan.
Loosen the three bolts in the mounts, raise the motor, and replace the mounts....Then rebolt them to the proper torque.
In theory, it is easy. It is reaching and cracking the bolts that makes ita pain.
That is how I did it in my Fox...I am not sure if it is different in the SN95.
Old 08-05-2007, 02:04 AM
Old_Smokey
Old_Smokey's Avatar
jack it up from the pan? I have to do mine too but that sounds risky as all hell. granted I cant think of any other spot to jack it up from.
Old_Smokey is offline
Old 08-05-2007, 07:18 AM
nitrous_bob
nitrous_bob's Avatar
a wooden block under the pan is fine , remember your just lifting the motor....not the car
and btw, you need to remove the fan and shroud first, then ubolt the mounts, then raise it
and atip, use 'vert mounts if you don't wanna buy energy suspension poly mounts
nitrous_bob is offline
Old 08-05-2007, 10:28 AM
CantStopTheFox...
ORIGINAL: nitrous_bob
All you need to lift the motor is like 4 or 5 inches....just enough to pull the old ones out, and slip the new ones in.
I did mine with the heads off so it was easy. I was actually able to stand inside the engine well and do it from the top with a socket wrench and a breaker bar. So if you plan on gutting your motor anytime soon, I would do it then
Old 08-05-2007, 11:15 AM
stang8689
stang8689's Avatar
I didn't jack mine by the pan but the side of the motor and did one at a time
stang8689 is offline
Old 08-05-2007, 12:49 PM
Asylum839
Asylum839's Avatar
Ok cool thanks, I guess ill try to do it next week when the parts come in the mail.
Old 08-05-2007, 01:22 PM
91lxstang
91lxstang's Avatar
i gotta do mine today cause im pullin the motor and i have no choice but to use hand tools.... its gonna suck
91lxstang is offline
Quick Reply: Motor Mounts
