replacing rack bushings
is it going to be difficult for me to replace my rack bushings? i've done a search and cannot seem to find any instructions. can i do it with rack's lines still hooked up?
RE: replacing rack bushings
Not really, if they are bad they will just about fall off the car once the steering rack is removed.
I did mine when I changed over to manual steering last year, just sort of a 'push them in' deal........
will i be able to leave the lines connected to the rack and move it enough to replace the bushings? same with the tie rods? i'm hoping i can just remove the nuts on the front and move the rack forward enough to replace the bushings.
i just replaced my rack a few days ago and found it easier to disconnect the lines after i pulled the rack out of the way a little. so yes you can replace the bushings without removing the lines. i would go ahead and look the rack over and make sure its in good condition. if your unbolting everything for bushings, its not much harder to replace the whole thing.
I never did the job...but I thought that you could pry the rack out enough (without removing any lines) to replace the bushings...
Here are some instructions....they are for Lowering Springs, but on step 25 they replace the steering rack bushings...
http://www.mustangworld.com/ourpics/fcar/spring2.htm
Those stars are supposed to be:
mustang world .com
All one word...
mustang world .com
All one word...
09-08-2015 11:50 AM
09-01-2015 08:16 PM
