Car Doesnt Restart After Reaching Running Temp????
i have a 1993 coupe with the basics heads cam intake injectors prom....the car starts up perfect in the morning and it will run perfect until you shut it off... it will crank and smell like its flooded but when you pull the plugs they are dry and clean...ive been trying to figure this out for like a month i think ive tried everything if any one can please help me...HELPPPP
RE: Car Doesnt Restart After Reaching Running Temp????
when you mean won't start are you refering to it cranks continuously with out firing up or do you mean it just plain won't crank or cranks very very slow as to not have enough voltage to fire up??
the car cranks but it wont start it has spark, smells like it has plenty of fuel. im running 32 degrees total timing cause for some reason when i try to put the plug for the timing advance the car wont run with it in
ORIGINAL: coupe9050lx
ORIGINAL: mattdel
your PIP is bad
your PIP is bad
ORIGINAL: mattdel
aye, might as well, since your already there.
BTW....you should run the DIY KOEO/KOER/Cylinder Balance Self-Test
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
