Broken Harmonic Balancer is this all?
RE: Broken Harmonic Balancer is this all?
ORIGINAL: 89 fox
and most importantly....remove the washer...you will be cussing, smoking and pooping even more trying to figure out why it is not coming off!
+8000 ya I ripped one of the threads right out of my old balancer doing that[8D]
Alrighty got down to that damn bolt, everyhing off i just need to figure out how to keep the balancer from turning while i try to crack this bolt sound about right to anyone? Anyone know what i can do to hold the thing from turning?
an easy way if you dont have air tools is too put a long rachet or a pipe on the end of a small one and hit the end of the rachet a few times with a hammer.you can put it in gear and have someone hold the brakes and then try to turn it.
I stick 2 pulley bolts in a couple of threads, use a 3 foot pry bar in between them and get the prybar wedged inbetween the bolts and the ground. If you have shop air, a impact gun works best through.
