f303 vs e303???
Old 08-15-2007, 01:44 PM
vtecwho
vtecwho's Avatar
Default RE: f303 vs e303???
^^ well i dont know what you had in there before but i have a E cam and on my dyno chart it pulls strong up to 5200 rpm and does not drop off, just levels. the low end is good but its like a 25shot of n2o at about 3500rpm. my car pulls hard all the way through. i dont know how high you want to send your rpms but if its past 5500 rpm to get your peak power your going to have to make other modifications to your cars engine.
i would REALLY do some research about different cams and your set up. the simpler the better. you dont need and those heads cant generally support high lift and decent durration cam.
joel50 is right. its not about the lift. the duration is what will make your valves and pistons collide and alow more air and more fuel to be brought in. i guess lift can compinsated for duration some what, but do your homework.
PS. my brothers car dynoed at 331rwhp with an E303 and afrs.and 10.1 CR. its not a BAD cam as everyone thinks.
vtecwho is offline
Old 08-15-2007, 02:19 PM
turbostang21
turbostang21's Avatar
if you have any intentions on going fi in the future.....go with the f cam for sure. many guys making big power with the f cam....a guy on turbomustangs made over 1000whp with one....and people say the alphabet cams are garbage
turbostang21 is offline
Old 08-15-2007, 02:22 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
alphabet cams are for little kids!!! lol get a comp cam or crane makes a godo cam too... edelbrock is so so
CrazyCobraSpeed is offline
Old 08-15-2007, 03:46 PM
frststang
frststang's Avatar
are any of these 2 camsuseablewith stock heads??
frststang is offline
Old 08-15-2007, 05:41 PM
Mustangkiler
Mustangkiler's Avatar
Crazy so the alphabet cams are for kids but the edelbrock is so so? You do realize the edelbrock cam is an overpriced e cam.
Mustangkiler is offline
Old 08-15-2007, 08:18 PM
FullAuto
FullAuto's Avatar
ORIGINAL: turbostang21
It's a turbo car. That makes it much more forgiving to junk parts. All you have to do is crank it up.
FullAuto is offline
Old 08-15-2007, 10:08 PM
telsonman
telsonman's Avatar
the heads are the only real thing that i'm dealing with. if the gt40s won't do much over .500 lift, then i'll get the e cam, but if they will handle around .512 then i'll snag a f cam.
telsonman is offline
Old 08-16-2007, 07:51 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: telsonman
You're worrying too much on peak flow numbers....and that's what they are, just numbers.... Regardless of the fact they're not too good in the flow "@.500" lift department", there are other factors you need to look at. Either choice, make sure that valve train (springs, retainers, etc) is upgraded though.
Joel5.0 is offline
Old 08-16-2007, 11:28 AM
turbostang21
ORIGINAL: FullAuto
i understand that and agree but my point is there's plenty of cams...custom grinds included... they will never get you that much power out of a 302 based combo....turbo/sc/nitrous or not
Old 08-16-2007, 11:57 AM
AdderMk2
Banned
AdderMk2's Avatar
definily think twice about getting an alphabet cam
AdderMk2 is offline
Quick Reply: f303 vs e303???
