Taking out the axles, please help!
I'm on my way to having a 3.73 but I'm having trouble getting the axles out.
What has to be done for them to come out? I have the calipers, rotors, and the diff. cover off, is there more to it that the clips falling out? Please reply ASAP, it's on jackstands
RE: Taking out the axles.
ORIGINAL: 1fastzook
push the axles in and take the clip out and thats it
Im having trouble popping out the C-clips though. Is there a trick? I've tried a magnet but they are too tight on the axle, I've triedneedle nose, but theres not enough space to grab each side, and my fingers are too big for the hole.
There is more then just putting the ring and pinion inside a you know .... just making sure...
Pinion depth,,, backlash , its not that easy sometimes.. takes time for sure with couple of tools
perfect time to check your wheel, carrier , pinion bearings , seals etc ..
