351c heads
RE: 351c heads
4bbl C heads are basically BOSS 302 heads. yeah, you can do it with either 2bbl or 4bbl heads. yeah, its definate power increase from stock. the problem most people have is you need different headers, intake, and some machine work to make everything go together properly. i think its cool as hell, but most people will tell you that you can make more power with aftermarket heads and its easier to do
RE: 351c heads
possible, yes.....
but just because you CAN, doesnt mean you SHOULD.
By the time your done with all the machine work, and find an intake that will work for you.... ya could have just slapped an aftermarket set of windsor heads on and called it a day.
RE: 351c heads
you cant use a 351c intake... it wont fit
you have to do some coolant passage modification, fab a coolant crossover.. etc etc
you can go ahead and try it... but there is a reason the cleveland stopped being produced
windsor FTMFW
windsor FTMFW
RE: 351c heads
by default a C design makes more power, regardless to what anyone will tell you. obviously aftermarket W is better than stock C, but aftermarket C has better potential (again, by inherent design)
RE: 351c heads
its more a matter of $$ than effort. CHIheads.com have EXCELLENT C designed heads that will bolt right onto 302 blocks and they even sell intakes for their heads for use on a 302 that gives you proper water passages, but you'll be in it 2k for a set of heads and an intake
