cold air vs ram air ???
Old 08-18-2007, 05:32 PM
ponyboy302
ponyboy302's Avatar
Default cold air vs ram air ???
which is better any advantages or disadvantages ? what are the differences ? and cold air in the fender or under the hood ? i have a stock 93 looking to start adding some ponies
ponyboy302 is offline
Old 08-18-2007, 05:59 PM
67mustang302
67mustang302's Avatar
Default RE: cold air vs ram air ???
Not much difference really, they both(if set up properly) will provide cooler denser air to the engine to help make a bit more power. The supposed ramming effect of ram air isn't actually realised unless you are at speeds over 100mph, and even then it's not much. Just get the air from as cool(and therfore dense) a source as possible
67mustang302 is offline
Old 08-18-2007, 06:22 PM
luckythirteen13
luckythirteen13's Avatar
the only 2 "ram air" kits that areworth a damn is a turbo kit or a supercharger kit.
cold air is cold air, doesnt matter where you pull it from. under the hood is not cold air
luckythirteen13 is offline
Old 08-18-2007, 06:34 PM
woodys5.0
woodys5.0's Avatar
its a 93 so you have amass air meter and it willonly meter so much air cold air fender kit is the best i
would say because it isclosed off from the air in the engine bay
woodys5.0 is offline
Old 08-18-2007, 06:52 PM
Mustangkiler
Mustangkiler's Avatar
cold air is denser and so you can fit more in an enclosed space, air flow sensor has nothing to do with it.obviously woody does not realize the idea behind it.
Mustangkiler is offline
Old 08-18-2007, 09:15 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
what gets me is a cold air will be made of metal and be chrome to make it worse....if itisn't plastic or at very least aluminum it's all for not.. unless you getting an ungodly amt of flow it might lower temp a few degrees at you T/B..and hell most of you guys have the tube to bring hot water thur your spacer so it's a total waste of time and $$$$$....what really matter is to have a straight SMOOTHshot of air to the engine and if a curve is nec. that it be a slow curve to not interrupt flow
2 kwik is offline
Old 08-19-2007, 01:11 PM
ponyboy302
ponyboy302's Avatar
isnt the stock set up plastic ? why would a cold air kit add a couple horses then ? is it the tubing or the air filter that makes the air cold? whats the difference between a stock set up and a mac cold air kit ..is it just a better filter and nice shiny chrome tubing ?
[IMG]local://upfiles/77059/CF695CF3D2ED4CB6AD8D3F6ADDDF38E5.jpg[/IMG]
Old 08-19-2007, 01:28 PM
nseoi
nseoi's Avatar
the COLD air part of this is the location that the intake gets its air from. if it gets it from the engine bay it is not cold. if it gets it from somewhere else (over the hood, fenderwell, lower bumper) its cold
nseoi is offline
Old 08-19-2007, 01:36 PM
luckythirteen13
ORIGINAL: ponyboy302
the difference between aftermarket and stock is the stock box has a sh*tty air filter. buy a K&N and its the same thing. also, remove the air silencer from behind the stock box and your ready to go
Old 08-19-2007, 08:12 PM
ponyboy302
ponyboy302's Avatar
thanks for all the help guys i think go got the whole cold air thing now : o) ....im looking up the parts and im finding a c l mass air meter and they are like $135 it looks like just for the small aluminum housing that the mass air sensor clip attaches too that was 73 mm then i found a mac fenderwell cold air intake with 2 tubes clamps the filter and what looked like the same peice to attach the mass air sensor clip too for about the same price but i couldnt get info on the size of it or the bbk ones ... is there a standard size for cold air intakes ?
Quick Reply: cold air vs ram air ???
