please help guys
please help guys
alright i installed my upper and lower typhoon intake....when i fire up the car there is an extremely loud whistling noise that is constant.....it sounds like its coming from behind the manifold....ive checked the pvc lines and vaccum lines coming out of the upper manifold....the sound is very annoying and it gets higher pitched as you rev the engine....what could this be??
RE: please help guys
its not coming from the throttle body though its coming from the driver side sounds like under the upper manifold where it sticks out over the driver side fuel rail
ORIGINAL: AdderMk2
how about you just assume that I know slightly more than you do.. mmk?
ORIGINAL: AdderMk2
your gonna have to deal with it... its a problem with ****ty intakes and TB's
your only option is to drill a 1/8" hole in the throttle body butterfly
ORIGINAL: Idrum88
why would the throttle body be making the noise its the same one ive always had??
ORIGINAL: AdderMk2
Im not some scientist that understand the exact airflow into the intake of your engine... all I know is... you get a whistle in your intake... you drill a 1/8" hole in the TB... jesus ... its not like I told you to shoot yourself
some people.. I swear ... I bet you didnt even use the search funtion... lazy
