Head Gasket?
Head Gasket?
I'm going to order a set of head gaskets this weekend and wanted to know what you guys think about FelPro p# FPP-1011-1 from Summitt. The only thing I don't know about is it says they are loc wire gaskets. Do I have to have my heads machined or the block machined for these? I like everything about these gaskets and they are the perfect fit except I'm questioning the loc wire. Any help would be greatly appreciated.
RE: Head Gasket?
i dont know much about the lock wire but have you considered the fel pros from auto zone?? i have all mods in my sig and the 15 dollar fel pros hold up great.
if your going to pull off your heads i would consider getting new ones, if you have stock. if your going to keep them i would recomend getting the heads re-surfaced and get a valve job.
RE: Head Gasket?
I got the Felpro 1011-2 head gaskets because thats what AFR recommended for my year, but i think the 1011-1s were recommended for fox bodies. I'm 99.9% sure they'll fit the stock engine just fine.
RE: Head Gasket?
felpro 1011-1 is not a lock wire gasket. i used to run them on my stock block motor. you dont have to machine the heads. they do have a steel ring around the cylinders, perhaps you just read it wrong. 1011-1 is what afr recommended to me because i was running boost with their heads
RE: Head Gasket?
This is why I was confused. It says loc wire - yes, but maybe this means something different. I don't know what though. This is from Summitt.
FPP-1011-1
$35.95
Brand:
Fel-Pro Performance
ProductLine:
Fel-Pro Performance Head Gaskets
PartType:
Head Gaskets
Bore(in):
4.100 in.
Bore(mm):
104.140mm
GasketMaterial:
Steel core laminate
CompressedThickness(in):
0.041 in.
CompressedVolume(cc):
9.000cc
LockWire:
Yes
Quantity:
Sold individually.
Notes:
Pre-flattened steel wire ring.[/align]
FPP-1011-1
$35.95
Brand:
Fel-Pro Performance
ProductLine:
PartType:
Head Gaskets
Bore(in):
4.100 in.
Bore(mm):
104.140mm
GasketMaterial:
Steel core laminate
0.041 in.
9.000cc
LockWire:
Yes
Quantity:
Sold individually.
Notes:
RE: Head Gasket?
if this hasent been cleared up yet loc wire is just a type...the one you want is steel wire ring head gasket, you can get the loc wire ones if you choose...Lock wire is an option...its part number on jegs is 375-1006
