trick flow top end kit
RE: trick flow top end kit
really man how much ? and would it fit a 89 mark vii its got the 5.0ho 302 in it? and would you be intrested in a brand new promatic 2 shifter and cash for it? lmk man got pics also real intrested. post up here or pm me man.
thanks stang what bout these i found em on ebay not sure if there any good or not though like i said i know like nothing bout injectors just learning bout em.
http://cgi.ebay.com/ebaymotors/8-For...spagenameZWDVW
i have the trick flow kit & like it . look closely at what you will get in the kit , you get a lot more than heads/cam/intake. also the trick flow heads have the 2.02 " valves that you can run with out cutting your pistons. the kit has easy to follow instructions. good luck either way
ORIGINAL: 97stang33
wats up guys i just bought my first fox bodys i was looking at a top end kit that trick flow makes does trick flow make a good product? its a track heat seires
the trickflow kit is a good kit if your lookin for a modest increase in hp.but like others say u could do better but u will need to research what u want to do with the car to decide what kind of motor u want to build
as far as research ... are you guys saying trick flow is the only company whos parts work well with its own parts such as h/c/i ??? like the holley intake is better than trick flow but its heads are not as good ... so youd have to buy a holley intake and research what heads work well with them ???
also how much extra gas is used when switching to 24 lb injectors ? if i was making 20 mpg stock what will i get if switching to 24 lbs /?/
