Valve Cover Rattle?
RE: Valve Cover Rattle?
could be either i will have to see the video but if its a ticking sound that goes awayb with higher reving then its prolly a collapsed lifter especially if its not as noticable cold and then gets worse as the motor warms up.
Sounds like a lifter acting up, add some marvel mystery oil to the engine oil, run it like that for a few hundred miles and change the oil. I had the same problem on my high mileage engine and it took care of the problem almost immediately.
I'm assuming aftermarket rockers? Is there enough clearance between the rocker and fill tube area. I found mine just lightly tapping mine a long time ago and had to go back in and grind more off. I also found that it caused my pushrod to be bent by a hair.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
