a bunch of mystery problems.
Old 08-29-2007, 09:34 PM
jakeachy
jakeachy's Avatar
Default a bunch of mystery problems.
so today i take the vert out for a not-so sunday drive.. when i get back there is oil leaking on the far right side under the engine. not a whole lot but its there. when i reverse there is like a rubbing feeling and noise. the brakes are getting bad. almost to the floor to stop her. I dont know where to start, nor do i have the time or equipment to check her over. helpzorz!
jakeachy is offline
Old 08-29-2007, 10:50 PM
jakeachy
jakeachy's Avatar
Default RE: a bunch of mystery problems.
somebody.
jakeachy is offline
Old 08-29-2007, 11:02 PM
mattdel
mattdel's Avatar
as far as the brakes go, start by checking the rear. out of adjustment or worn components will give a low pedal, because rear brakes are activated first, the fronts won't receive pressure until the rears hit.
mattdel is offline
Old 08-30-2007, 02:00 AM
Alero99
Alero99's Avatar
interseting.... cuase i have to floor my brakes to stop, makes high way driving...
interesting.
Alero99 is offline
Old 08-30-2007, 10:20 PM
aode08
aode08's Avatar
ORIGINAL: Alero99
interesting.
you got *****
common sympton of a rear wheel cylinder seeping and or possible master cylinder /brake booster failure
aode08 is offline
Old 08-31-2007, 07:51 AM
Jfsram
Jfsram's Avatar
Jack up the car, remove all 4 wheels, rear drums and have a look around.
Then post your findings.
Jfsram is offline
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
trashxtrash
09-20-2015 10:49 PM
09-08-2015 06:25 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: a bunch of mystery problems.
