car runs better with maf unplugged?
along with the s/c install we did 75 mm pmas maf calibrated for my new 30# injectors, ive been having problems getting the car to run right https://mustangforums.com/m_3787376/tm.htm so we tried uplugging the maf just to see what would happen, it made the car start up and run alot better what do you guys think could be the problem
RE: car runs better with maf unplugged?
Wouldn't hurt to clean it or at least check the wires. Could be damaged or have some residue on it. I didn't realize that their kits came with a new MAF as well. Are you sure they sent you ne calibrated for ht right size injectors?
If it's so bad that the car runs better without the MAF plugged in, then that must mean that the default tables are better than what the car is getting for fuel trim information from the MAF. Could be any number of things. Liek I said, it could be the wrong MAF. Or maybe the wrong injectors or something. I was just recently sent an X-pipe that said it was for a 1995 5.0. The packing spli and everything said that. But it was actually for a 1996 4.6L Mustang. It was labeled wrong.
The MAS wires are also VERY delicate and could have been damaged during shipping. Check to make sure both of the wires are intact. Also, like I said, make sure it's clean and doesn't have anything attached to it.
