I must be bad at searching, but... torque spec help
Old 09-04-2007, 09:25 PM
plsirl
plsirl's Avatar
Default I must be bad at searching, but... torque spec help
My manual is a couple hour drive from me and I am trying to find the torque specs for :
engine to bellhousing (6 bolts)
flexplate to torque converter (4 nuts)
mounts to engine (4 bolts)
I tried searching the forum for all of these, which I feel like I had stumbled upon in the past, but cannot find them. Oh, I did find, " mount to motor: 45-59 lb-ft" is this correct?
It is a '68 Mustang with a C-4, and a '91 302.
Thanks a ton for any help!
plsirl is offline
Old 09-04-2007, 09:31 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: I must be bad at searching, but... torque spec help
Honestly, tight. I've never torqued any of that in 25 years of working on cars. I just did the clutch in my car last Friday. What was the torque setting, tight.
PRO50SC is offline
Old 09-04-2007, 09:33 PM
plsirl
plsirl's Avatar
Haha, I figured that might be the case. Thanks a ton.
plsirl is offline
Old 09-04-2007, 09:42 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
In the end, it's your car and you should do what's comfortable for you.
PRO50SC is offline
Old 09-04-2007, 09:46 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I agree with Pro....
Hell I even work for Ford and we dont follow every single torque spec. Every nut/bolt has a torque spec, but only critical compenents need to be looked at. Unless you have the time and right tools to do it all the way the book says..
WhiteFoxGT is offline
Old 09-05-2007, 01:25 AM
plsirl
plsirl's Avatar
thanks a tone for the tip whitefox.
plsirl is offline
Old 09-05-2007, 06:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the only torque spec you really need to follow are head gaskets,rod and main cap torque and intake manifold torque and possibly oil pump torque but I usually put loctite on those two bolts other than that the rest "tight will suffice"
mjr46 is offline
Old 09-05-2007, 10:04 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: PRO50SC
I agree.. Usually the bellhousing to engine bolts and tranny to bellhousing... I typically just put them in tight, with some blue thread locker
AdderMk2 is offline
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
wraith777
09-28-2015 10:49 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: I must be bad at searching, but... torque spec help
