dropping front swap bar
Old 09-06-2007, 11:29 PM
LCBlackDep183
LCBlackDep183's Avatar
Default RE: dropping front swap bar
Just dont try and take a hairpin turn like your in a lotus and you'll be fine...
your in a mustang anyways you shouldnt be trying to take 90 degree turns a t 70 anyways.
LCBlackDep183 is offline
Old 09-07-2007, 01:06 AM
liketoskate1
liketoskate1's Avatar
well heres the thing my car is already set up for the twisties im running like 850lbs spings and larger front sway bar strut tower brace..... so it handles like a lotus lol but it doesn't hook for ****... i just want to do something quick before going down to run. as is i cant get better than like a 2.4/2.3 60' w/ new 275/45/zr17' g force tires.... all i want right now is to get in the 8's in the 1/8th mile, my best right now is a 9.4 w/ a 2.4 60' time at 78mph so yeaanyone know of some quick things i can do to lower my short time?
liketoskate1 is offline
Old 09-07-2007, 01:13 AM
w8less
w8less's Avatar
some slicks and a good launch should net a 8 sec slip like you want.
w8less is offline
Old 09-07-2007, 01:15 AM
LS1this
LS1this's Avatar
I have yet to run the stang, but in my old supra I had pretty good luck with lowering the tire pressure to around 20-25psi, doing a burnout and slipping the clutch out some at 4 grand. It also helped when I ran with 3/4 of a tank of gas or more vs under a 1/4 tank, the extra weight over the rear tires helped it hook.
I was able to cut 1.9 60's on 255 falkens like that.
what is your launching technique? also are you spinning just 1 tire? your lsd could maybe use a rebuild
LS1this is offline
Old 09-07-2007, 01:22 AM
liketoskate1
i do basicly what you said below..... and i got 3.55 gears that were rebulit in like 01 and still spins both tires but ive been running it like a 1/4 tank cause gas is so heavy but mabye i'll try running a little more.....
ORIGINAL: LS1this
Old 09-07-2007, 01:44 AM
w8less
w8less's Avatar
do you have upper or lower control arms
w8less is offline
Old 09-07-2007, 09:09 AM
liketoskate1
no i dont i need to get some..... what brand do you like? will they negitively affect my handling in any way?
ORIGINAL: Jasperstang308
Old 09-07-2007, 09:39 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
UPR u/l arms. 200 bucks then shipping. cant beat it.
FivePointOhh is offline
Old 09-07-2007, 09:57 AM
WhiteWindsor
WhiteWindsor's Avatar
You can beat upr as far as quality, but def. not the price.
WhiteWindsor is offline
Old 09-07-2007, 10:50 AM
w8less
w8less's Avatar
ORIGINAL: FASTBLACK
upr is still better than the blue oval crap people were spitting out several months ago.
u/l control arms and sfc for like 150 bucks
w8less is offline
Quick Reply: dropping front swap bar
