Nitrous - Common point of detonation?
Will I have any detonation running a 75 shot with 14 degrees of timing? I've heard that it will not detonate but then i've heard I should go all the way down to 8 degrees of timing witha 75 shot.
I haven't used the spray yet and want to know what I should set my timing at for the 75 shot... Help me out guys!
-Jeff
-Jeff
RE: Nitrous - Common point of detonation?
ORIGINAL: nothsa
-Jeff
-Jeff
ORIGINAL: 88ttops
You may not but i would back it off like 2-4 degrees and run a 1 shade colder plug... Whats the engine worth to you to find out???
ORIGINAL: nothsa
-Jeff
-Jeff
It's not worth blowing up, I plan on spraying a 150 shot on it when I get a new fuel pump.
-Jeff
ORIGINAL: 67mustang302
A lot of it depends on your setup. Wet or dry, if wet with what fuel etc
-Jeff
ORIGINAL: FullAuto
I've never spray 75hp, but if I did, I'd have it on 13-14*.
What about a 100 shot and 125 shot? I plan to up the spray really fast, I just haven't run nitrous before and want to progress from the 75 shot up.
For the 75 shot should I lower my timing just to be safe? What shot can I safely go up to without getting the car tuned? Can I just keep changing my timing and be okay?
-Jeff
ORIGINAL: nothsa
When should I go colder on the plugs? I have a a set of plugs that is two steps colder is that okay to use?
ORIGINAL: FullAuto
