speed bleeders
Old 09-09-2007, 09:23 AM
dillon1340
dillon1340's Avatar
Default speed bleeders
anyone use these before? do they really work as well as they advertise?
dillon1340 is offline
Old 09-09-2007, 09:28 AM
my77stang
my77stang's Avatar
Default RE: speed bleeders
i've never used em but i've never heard anyone say they didnt work
my77stang is offline
Old 09-09-2007, 07:52 PM
tinman
tinman's Avatar
I've been using these for probably 10 years.
They do work.
I like to use a section of vacunm hose on the end of them and run the hose to a can or bottle or something to keep old brake fluid off the floor.
Also remember, once brake fluid has been put thru the system, it's no good any more unless you want to start the bar-b-que with it....
tinman is offline
Old 09-09-2007, 08:54 PM
Jmunk
Jmunk's Avatar
If your referring to the speed bleeder, bleeder screws, than yes. I about them for all four corners last week and was able to bleed the whole system out after a master cylinder change. Took under 10 min to bleed all four corners after I installed the bleeder screws, I reccomend they, worked great for me to bleed on my own.
Jmunk is offline
Old 09-09-2007, 09:14 PM
tmajikman
tmajikman's Avatar
Where do you get them, at any auto store, they sound like a great idea.
tmajikman is offline
Old 09-10-2007, 09:46 AM
Jmunk
Jmunk's Avatar
I got mine at carquest. The book had the wrong part number for the rear, the ones that I got that worked for the rear are 12703, they are the HELP brand and in a red box.
Jmunk is offline
Old 09-10-2007, 08:12 PM
dillon1340
dillon1340's Avatar
ORIGINAL: Jmunk
that's awesome they worked. i'm gonna buy some then. when you did your master cylinder did you bench bleed it? i heard that they don't come with the bench bleeder tubes anymore and was not wanting to buy tubes to do this.
Old 09-10-2007, 08:36 PM
88BlueGT
88BlueGT's Avatar
I have Russell speed bleeders, never used them though yet.
88BlueGT is offline
Old 09-10-2007, 09:28 PM
Maxwelhse
Maxwelhse's Avatar
Just stick a chunk of rubber hose over the top of your factory bleeder, put the other end in a cup of brake fluid (so it can't suck air), crack them slightly, and pump forever...
Free "speed bleeding"... Just have someone hold pressure on the system while you close the bleeders.
Maxwelhse is offline
Old 09-11-2007, 09:29 AM
ruger311
ruger311's Avatar
i agree with the hose and cup method no problems here just dont pull any air into that system
ruger311 is offline
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
BeatnikFink
10-01-2015 08:00 PM
mungodrums
09-29-2015 09:18 PM
musnicki
09-23-2015 07:11 AM
Quick Reply: speed bleeders
