front suspension kit>?
Old 09-10-2007, 10:39 AM
kweb288
kweb288's Avatar
Default front suspension kit>?
hey guys im looking to do the suspension on my fox ext, (it is a drag orientated car) i plan to do the whole 9 yards, k member coil over and the likes. my question is, is UPR pro series kit a good choice? or should i (i dont want to) dish out the money for a racecraft set up (4x's as much) or is their another vendor out there i should look at? thanks for the help
kweb288 is offline
Old 09-10-2007, 11:13 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: front suspension kit>?
there is a guy on here who bought UPR's tube k member. he liked it, said it bolted up easy lost a ton of weight and performed well. i say go for it. everyone else says its a great kit
FivePointOhh is offline
Old 09-10-2007, 11:17 AM
kweb288
kweb288's Avatar
ok thanks for your help. do you know what kind of struts you use? do you just get regular struts and put the coilovers over them or is it a special coilover strut that is needed?
kweb288 is offline
Old 09-10-2007, 11:23 AM
andywear87
andywear87's Avatar
what about the rear is the pro kit for the rear also as good
andywear87 is offline
Old 09-10-2007, 11:32 AM
kweb288
kweb288's Avatar
i heard it was...but dont have it.....yetSubway only gives me so many hours lol and with college it takes for ever to save up any kind of money for this damn project
kweb288 is offline
Old 09-10-2007, 11:42 AM
andywear87
andywear87's Avatar
i am looking at suspension and have the money right now and want to buy the pro series front and rear kit together caster camber plates srprings for the rear and shocks and struts. cuz my car dont hook for ****
Old 09-10-2007, 11:49 AM
ZachW04Stang
ZachW04Stang's Avatar
I have uprs rearsuspension and its great. There customer service is top notch too. I had 2 defective hiem joints on my left upper control arm and upr sent me 4 for free to fix the problem. I also have uprs coil over kit and I like it a lot.
ZachW04Stang is offline
Old 09-10-2007, 12:00 PM
andywear87
andywear87's Avatar
do you have the tubular k member up front? how much did the coil overs lower your car in front?what springs did hyou go with on the rear and what strut/shock combo did you go with? my car is a street car i want hhcornering and hookup not just straight line hook up
Old 09-10-2007, 02:28 PM
kweb288
kweb288's Avatar
you can use a 351w with that k memeber correct? i know you will need new engine mounts just making sure it will be compatible with the engine
kweb288 is offline
Old 09-10-2007, 02:42 PM
FivePointOhh
in limbo
yes. mount are in the same stock location for UPR
Quick Reply: front suspension kit>?
