Almost Positive its a miss now
Old 09-13-2007, 06:58 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
Default Almost Positive its a miss now
When my car idles, its got a rough idle, and about 1-2 times a second i feel a "bump" is the best word to describe it, and whenever it "bumps" the idles go down a lil bit, so by now im almost positive its a fuel related miss, because it doesnt backfire.
im wondering, is it worth it to try and clean my injectors, or should i just buy a new set (19lbs is stock, right)
i threw some V-Power 91 octane, and a bottle of injector cleaner, and it didnt do squat, so either im wrong, and its a vacuum, or im right and the injector is too fugged to be fixed
FuzzyDiceRule is offline
Old 09-13-2007, 07:01 PM
mattdel
mattdel's Avatar
Default RE: Almost Positive its a miss now
could be alot more than that.
bad plug wires, bad plug(s), TFI or PIP module, coil....
i wouldn't bet on a vacuum leak
mattdel is offline
Old 09-13-2007, 07:03 PM
nitrous_bob
nitrous_bob's Avatar
yes it's a miss i'm sure, why don't you think electrical related though ?
nitrous_bob is offline
Old 09-13-2007, 07:25 PM
AdderMk2
Banned
AdderMk2's Avatar
I'd laugh if he had a block to chassis ground problem
AdderMk2 is offline
Old 09-13-2007, 07:26 PM
FuzzyDiceRule
why would that cause a miss, and where are those, its worth a check
about now, im just gonna spend mah 400 on a new ignition, cap, wires, plugs, and injectors
i think they ruined one of the wires when we got my engine steam cleaned, so...
Old 09-13-2007, 07:30 PM
AdderMk2
Banned
AdderMk2's Avatar
Thats the spirit.... If you don't know whats wrong... just throw some money at it..
AdderMk2 is offline
Old 09-13-2007, 07:41 PM
ACE
ACE's Avatar
Wait how long ago did you get the engine steamed cleaned? If it was fairly reciently and you noticed the miss AFTER the cleaning, try wiping out your cap and inside your dizzy and all the plug wires and clean the coil where the coil wire goes it. You might have condensation in one of those connections and giving you a bad spark! I have learned that with my bronco after I cleaned it.
ACE is offline
Old 09-13-2007, 09:25 PM
FuzzyDiceRule
i used a timing light on all the plug wires, theyre all firing,
for the record, its this idle thing, it seems to run fine at higher RPM, but it has a lack of power
we got the engine cleaned a WHILE ago, so i dont remember
my best guess is a faulty spark plug or a semi clogged injector
Old 09-13-2007, 09:29 PM
AdderMk2
Banned
AdderMk2's Avatar
did you ever think of maybe putting a new set of plugs in it... autolite 25's...
with some silver antisieze compound
at $1.48 each, its not exactly breaking the bank
AdderMk2 is offline
Old 09-13-2007, 09:42 PM
FuzzyDiceRule
yeah, dude, i said earlier im gonna buy a new cap, coil, wires, plugs and injectors, all but the wires are stock, but i dont like blue plug wires
Quick Reply: Almost Positive its a miss now
