usaly a bouncing pin is a sigh of a worn out speedo cable, could be the speedo cluster gears inside making it bind up too... just order both from a magize. maby you should drop in one of those cool saleen speedos!!! i think its a 200mph speedo,and maby upgrade your guages to white face while your at it
i would be money it is the speedo off balance, it happens after a while, more common with the 140's than the 85's.... could be cable but i would doubt it, but the cable is a easier and cheaper fix, i would try that, if fails then pull out speedo.... i had one that did that and the little metal weight on the speedo was a little bent, i just straightend it about the best i could and made sure the needle was straight, put it back in and it worked like a charm..... but you could buy 140 speedo clusters off ebay for 50 bucks, give or take.... i paid 75 bucks and bought a cluster with a bbk 180mph speedo
