i don't know what happend....
Old 09-20-2007, 08:28 PM
jhMGT
jhMGT's Avatar
Default i don't know what happend....
i replaced my stock manifold with a cobra manifold and now nothing seems to run right. i had to reset the timing, so thats fine now but it's still hard to start and once it's started, it idles rough. maybe a vacuum leak who knows. Is there anyone in north jersey (specifically essex county) who can help with this problem? i'm pretty frustrated with the car right now so any help will do. I'm pretty good with cars, but i'm pretty baffled and worn out. when i say help i do mean come to the car and fix it. i will pay for whatever needs to be done ( obviously) HELP
justin
oh it's an 88 mustang GT
jhMGT is offline
Old 09-20-2007, 08:42 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: i don't know what happend....
check all your vac lines just to be sure. break out a can of carb cleaner and start searching. if you cant find any vac leaks try working your timing again. remember to disconnect spout connector just start at 10* until you find your problem. set base line idle as well. remember to disconnect IAC as well while doing this.if those all fail maybe you stabbed your dizzy in one tooth off. thats very possible. try those and if you cant find it lemme know...
FivePointOhh is offline
Old 09-20-2007, 08:43 PM
FivePointOhh
in limbo
are you speed density or MAF?? or carb...
Old 09-21-2007, 10:56 AM
jhMGT
jhMGT's Avatar
I have speed density. i reset the timing, so that doesn't seem to be the problem. the car turns over fine. i actually got it to start last night, but the idle is very rough. i think i need to block off some vacuum lines. i'm sure most of you know that the cobra intake is slightly different from the stock. As i stated before i'm pretty frustrated at this point and i need my car to run.
jhMGT is offline
Old 09-21-2007, 10:59 AM
WhiteWindsor
WhiteWindsor's Avatar
ORIGINAL: jhMGT
If you have unplugged vacuum line's laying around, that is your problem as i am sure you know that if they are not plugged you will have a leak.
WhiteWindsor is offline
Old 09-21-2007, 11:23 AM
Texas5.0
Texas5.0's Avatar
Sounds stupid but make sure plug wires were hooked up correctly.
Texas5.0 is offline
Old 09-21-2007, 11:45 AM
7upedition
7upedition's Avatar
-Vacuum Leak
-Base Idle Screw Set?
-Reset base timing w/ dizzy unplugged?
-Double Check wires
-Did you torque down in proper sequence?
7upedition is offline
Old 09-21-2007, 11:49 AM
WhiteWindsor
He's already said he has unplugged vacuum line's, that is the problem.
Old 09-21-2007, 12:26 PM
FivePointOhh
in limbo
so....basically all of it was address in the first response....lol
firecoyote
09-27-2015 02:37 PM
2015Ecoboost
09-17-2015 01:48 PM
Roush05
09-10-2015 12:23 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: i don't know what happend....
