Victor Jr. Heads
Old 02-24-2005, 12:33 PM
pena8759
pena8759's Avatar
Default Victor Jr. Heads
Hey Guys,
Just wanted to get some advice from the guru's here. Will a e303 cam work with victor jr heads with 1.7 tfs roller rockers, tfs street upper and lower intake. Please help!!!![sm=dontgetit.gif]
Thanks in advance!
pena8759 is offline
Old 02-24-2005, 12:36 PM
stanglx2002
stanglx2002's Avatar
Default RE: Victor Jr. Heads
why dont you get AFR heads they are better
stanglx2002 is offline
Old 02-24-2005, 12:47 PM
primetime5.0
primetime5.0's Avatar
man afr this afr that, maybe he doesnt want afr's? ever think about that? I dont see why they wouldnt work you may have piston to valve clearance issue but im not positive
primetime5.0 is offline
Old 02-24-2005, 01:07 PM
pena8759
pena8759's Avatar
Well this is the set up my buddyhas. He currentlt has this on but with a crane cams with .544 lift. Myself and many other people have told him that this set up will not work. That he will need to change cam and heads. It is to big for a stock bottom. So I was just wondering if just a cam swap will work.
pena8759 is offline
Old 02-24-2005, 01:13 PM
stanglx2002
im outtin in a Ecam and 1.7 corba RR and it will be fine.
the heads im not sure if you will have to notch the pistons or not
Old 02-28-2005, 09:11 PM
619socalstang
619socalstang's Avatar
piston notching is a must for Vic jrs. good choice i dont like AFR's even if every body says there better, thay can keepum.
619socalstang is offline
Old 02-28-2005, 09:13 PM
stanglx2002
whatever you say most people say AFR
Old 02-28-2005, 09:33 PM
Dan89lx
Dan89lx's Avatar
victor jr's will drown that motor with that small cam, get a bigger cam or consider smaller heads, also, piston to valve clearance will be a big issue since the victor jr. has a 2.05 intake valve
Dan89lx is offline
Old 02-28-2005, 10:55 PM
86HOGT
86HOGT's Avatar
Why does everyone say AFR, AFR? Because they get the job done and then some. I've seen it first hand and I"m sold on them when I get heads, and won't look back, becuase it's all about doing things right the first time.
86HOGT is offline
Old 02-28-2005, 10:59 PM
stanglx2002
thats right if you are going to do it do it right and get the most out of it so if they are the best and get you the most why get any thing else
Quick Reply: Victor Jr. Heads
