400hp lx
400hp lx
you have parts eh? I am looking for heads and a cam for my future 5.0 engine. It is more efficient to pull out my 86 engine and pop in a rebuilt 5.0 with the new stuff on it.</P>
</P>
you have anything to offer me.</P>
also, i know people do, but i dont see how they can get 400 hp or more on a 5.0.</P>
i mean i am looking at getting heads, cam, my trick flow intake, 70mm tb&egr. and still i dont even expected to get into 300hp! </P>
</P>
except for the engine work and the tiddly things like exhaust and stuff, how does one get to 400hp?</P>
400hp lx
With:
heads
intake (manifolds, egr, tb, maf)
cam
injectors
fuel pressure regulator
and some misc. stuff
I'm at ~330-350. If I had used 10:1 instead of 8.5:1 compression ratio I'd be a lot closer to 400.
To get there, add a stroker kit, supercharger/turbo, N2O, even more wild cam, etc.
The shop that built my engine has an old mustang with a 589 that's whipping out over 1000hp. Of course that's a small shot of N2O and a huge blower.
heads
cam
injectors
400hp lx
bored .040 over
stage 3 heads
rpm upper and lower intake (ported and polished to match the heads.
stage 3 computer
75 mm maf
70 mm tb
steel forged crank
eagle connecting rods
srp high compression forged pistons( 11.5.1 )
1.7 roller rockers ( cobra )
comp push rods
roller lifters
e 303 cam
centerforce 30lb flywheel
24lb injectors
190 lph fuel pump
pulleys
373 gears
bbk cold air
msd 6al ignition
equal lenth ceramic coated headers
bassani x
flowmaster
a lot of suspension
stage 3 heads
stage 3 computer
75 mm maf
70 mm tb
steel forged crank
comp push rods
roller lifters
e 303 cam
24lb injectors
190 lph fuel pump
pulleys
373 gears
bbk cold air
msd 6al ignition
bassani x
flowmaster
a lot of suspension
400hp lx
i dont see how you7 can do all that and i cant een decide on what heads/cam to use.</P>
i was thikning steeda 19, but thats for 94-95 engine so says partshopper.com, this is what it says. Neither of my cars info fits the cam recommendations exactly:</P>
</P>
<TABLE cellSpacing=0 cellPadding=3 width="97%">
<T>
<TR>
<TD width="100%">
<FONT face=Tahoma size=2>Use #18 for:
RPM Range 2500-6000</FONT>
<UL>
<LI><FONT face=Tahoma size=2>87-93 (mass air) cars, carbureted engines</FONT>
<LI><FONT face=Tahoma size=2>3.73-4.56 gears</FONT>
<LI><FONT face=Tahoma size=2>manual tranny</FONT>
<LI><FONT face=Tahoma size=2>lighter cars</FONT>
<LI><FONT face=Tahoma size=2>351 engines</FONT> </LI>[/list]
<FONT face=Tahoma size=2>Use #19 for:
RPM Range 2200-5800</FONT></P>
<UL>
<LI><FONT face=Tahoma size=2>94-95 Mustangs</FONT>
<LI><FONT face=Tahoma size=2>3.55-3.73 gears</FONT>
<LI><FONT face=Tahoma size=2>AT (3.73 to 4.10 gears recommended)</FONT>
<LI><FONT face=Tahoma size=2>heavier cars</FONT>
<LI><FONT face=Tahoma size=2>smoother idle than Motorsport or #18 Cams</FONT> </LI>[/list]</TD></TR></T></TABLE></P>
